CapnBry
Last week ended with some pretty awful weather here, wind gusting up as high as 40kt so flying has been a no-go. I had been seeing some weirdness in the servos that would come and go. You could actually see it in the blackbox logs as the gyros would suddenly show a lot of noise so I've used the time to try to work out what's going on. The servos would just jitter back and forth, sometimes a small amount, sometimes a lot (3mm maybe?). I tried a buncha stuff:
Turns out when the FrSky R-XSR receiver is anywhere near the servo wires, they start moving on their own. The closer the wires are to the receiver, the more they move. This is sort of a problem when the servo wires have to go somewhere and everything is within 25mm of any other thing due to how thin the fuselage is. Even the shielded portion of the antenna wires seems to cause it to some degree. I've never experienced this before, and I've built a dozen different planes with all the components just sort of shoved in there wherever they fit. I think the bare receiver plus the super-thin servo wires (I'd swear these are like 30AWG, so wee) induced interference. I have worked around this slightly by pushing the receiver up into the top corner and running the servo wires along the bottom and holding them down there. You can still hear the servos moving slightly, but the control surfaces aren't moving enough to see. I also used the ole ziptie+heatshrink trick to make some little masts to move the active elements further away.
Wow that foam looks worse in each successive photo. You may also notice that the top of the fuselage is cut behind the antennas. Oh that's just because in all my servo testing, I ended up hooking one of the servos up with the 5V and GND wires reversed and apparently that's not a good thing and I had to cut the fuselage and break the glue up with some denatured alcohol to get the servo out to replace it.
I managed to fly twice on Sunday, 25 minutes each flight on 600-750mAh of battery despite not being what I'd think was a good thermal day. Just cruising around with no throttle I'd be at 100m, then a few seconds later I'd look over and I'd be at 110m and really have to force the nose down to keep it from climbing. 10km of distance traveled, with a max of 305m from home (EDIT: the disarm screen said 452m max but the highest I see in the video is 305m). Pretty good for the generic $14 AIO 25mw FPV camera from Amazon. Definitely making me think more seriously about getting my license to use a more powerful transmitter.
- Put torroids on the power input and the servo wires, individually and all of them.
- Use a second 3A 5V power supply BEC for the servos only.
- Use a second battery to power the servos (with the ground wires linked)
- Put capacitors on the 5V line, from 100uF to 3500uF
- Put a supercapacitor on the 5V line, 1F.
- Make a new servo cable to connect to the flight controller, thinking I must have gotten the wires shorting.
- Twist the servo wires to make them more resilient to noise.
- Change the CH1 and CH2 inputs to switches on the transmitter so they always output 1500us, to make sure the jitter wasn't coming from gimbal sampling errors.
![PICT0007.AVI_snapshot_00.54_[2019.04.23_09.21.41].jpg PICT0007.AVI_snapshot_00.54_[2019.04.23_09.21.41].jpg](https://ftforumx2.s3.amazonaws.com/2019/04/225602_f70d9949262cf0b9240c8e1e131e5d9b.jpg)
