b-29er
Some suggestions on a v3? ok
-use a way lower KV motor, like under or near 1000kv motor, maybe the motors the DJI quads use. Water is a lot more dense than air, and i would believe you want controllability over speed. Then you could still use your 4 or 5" props and get a lot of thrust at low RPM so you don't cavitate
-Figure out your cooling. You could cut a hole in your pipe to mount a metal plate to mount your ESCs to for direct passive cooling, or use boat ESCs and run a pump for active cooling.
-RUNCAM SPLIT so you get full HD recording and a live uplink without strapping a camera externally
-mount everything to a small boat with apm: boat so you can have a base station further out on the water that holds position by gps. Then use a regular fpv tx/controller to run from wherever you like.
