Hi FliteTest community! I am a senior in high school with the opportunity to partake in what is known as a "Senior Project". Basically, instead of taking a class, I am given the time to pursue any project I want. Back in October I was suddenly inspired to build a quadcopter. I had little to no flight experience, not to mention any clue of how to build a multirotor. Like many of you, I stumbled upon FliteTest and was immediately hooked. Over the winter (very cold in the northeast), I spent hours researching and planning for my project. I even taught myself to fly in below freezing conditions with two feet of snow. I spent the time making drawings and renders in Sketchup, as well as plan out the stages of my project.
My school divides the year into four terms, and I am very excited to say that now is the term that my project officially begins. I have from April 4th to approximately May 25th to complete my project goals and I will be using this thread to catalog my build. After the project is over I hope to turn this thread into an interesting article.
Here are the basic goals for the project:
-Construct a basic quadcopter and learn to fly
-Contruct and calibrate a brushless camera gimbal
-Film aerial video of various locations with the gimbal
-Develop autonomous (waypoint) flight
-Test out other quadcopter abilities (flips, lifts, etc)
And with that begins my build log...
I started where most people begin, which is with the frame. I went to Lowes and purchases some 1/2" square dowels, a 3/8" square dowel, some hardware, and spray paint. I used templates and measurements I made in my plans to cut out each piece of the frame.
The landing gear is based on the Hobbyking X666 frame. I designed the frame to have the smallest main plate area as possible, but still be able to fold together. I settled on a 4.5" square plate in the middle and 12" arms. I managed to break my coping saw in the process of cutting the landing gear, but eventually ended up with all the parts. I put everything together for a rough look and then proceeded to paint (The landing gears are clamped because they get attached with zip-ties along with the motors).
For the paint job, I decided to paint two arms black and two white for orientation help. I had enough wood for two extra arms which I paint red to signify if an arm was replaced. Two coats of paint with sanding in between and it the wood looks like aluminum or plastic if you stand far enough.
This concluded the frame for now as I am still waiting on parts from Hobbyking (its killing me), but you can begin to see its resemblance to this rendering I made:
With time to spare I decided to begin work on the camera gimbal. Again, I have not electronics so I have built all the parts, but could not do any final assembly. The gimbal is made out of wood and is designed to be adjustable along 3 points to allow for balancing. The parts are are based on this model I made:
It has been one week so far into this project and I am very pleased with my progress so far. The only frustration is the lack of electronics. I will update this thread with updates as often as possible and I will try to answer any comments or questions. Thanks and enjoy!
