Robbie
Hey Guys,
Me and my flying buddy Ocean are currently despairing. We are trying to work out whether we can continue flying miniquads. We are both very capable pilots and we are able to fly advanced FPV and LOS acro with no issue but we are probably going to have to stop flying soon because of the sheer cost of flying mini quads.
For example today was an average day flying and here are the casualties:
Apart from one LOS crash by me where i attempted to do a triple flip and a few knocks from light crashes... not a single one of the crashes was our fault. There were 4 bad FPV crashes the causes of which were:
1. Prop chuck
2. Prop blade simply coming off mid air (caused probably by excessive stress on the blades)
3. control loop/ESC error (no proof just seems the most probable explanation as there did not seem to be a prop chuck or a blade chuck), Quad simple fell out the sky
4. Unknown.
All of these crashes were beyond our control and yet the cost of them was severe, I was curious if any of you experience the same horrific costs and if there is anyway to reduce them.
My build:
Frame: Emax 280
Motor: Emax 2206 1900kv
ESC: Rotorgeeks 30A
Props: 6045
Flight Controller: Naze 32 (PID 1)
Rates: Roll & Pitch: 0.75, YAW: 0.80 TPA: 0.15 - Reason for high Rates - I want to be FGA :0
Oceans build:
Frame: ZMR 250
Motor: Sunnysky x2207 2100kv
ESC: Rotorgeeks 30A
Props: 6045 Gemfan
Controller: Naze32 (Luxfloat)
PIDS: Roll & Pitch 0.4, YAW: 0.40, TPA 0.1
Granted these rates are high but both Ocean and I are good enough pilots to control them and it just angers us how we can't fly as much as we would like because of the issues that plague our quads.
Do you guys have the same issues and are you struggling to pay for you quad?
Thanks guys.
Robbie
*Edit Tips I learnt today.
1. IF you have a large VTx with a large antenna e.g 1.3/2.4Ghz, Velcro it on, that way it comes off easily in a high speed crash.
2. Always check props and prop nuts before a high speed/ high G run
3. Depending on where you mount your battery use a battery extender (about an inch or two of wire with a female to male xt60) This will put less stress on your battery connector in the event of high speed low FPV crash.
4. DO NOT USE TIP 3 for LOS acro, or you will find (as I did) that these extra connectors are prone to coming loose while doing flips and tricks and suddenly you have a 200g battery flinging around.
5. Do a quick visual check of your Quad with every new battery or crash, so often its tempting to just go straight back up and let issue present themselves as you fly but I promise you that is not the best cause of action.
6. Be careful using cheap plastic props again after a crash. Because often stress is put on the blade during a crash which can lead to cracks and fatigue in the prop which are not easily visible to the naked eye. The good thing about HQ props is they shatter instantly.
7. Zip Tie as many cables down as you can, a neater quad is a cheaper quad.
8. Check battery straps and that battery is tighten securely, a 250g 4S carries a lot of momentum when doing flips and tricks in acro, this can lead to the battery coming loose in some cases coming right off. Also probably not a good idea to fly your 250 FPV racer as if it is a warp quad![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
40+ Gemfan 6045 props
2 Lipo batteries (connectors ripped high speed crashes)
VTx, crash ripped off and bent the aerial.
3 connectors and wires.
3 prop nuts
1. Prop chuck
4. Unknown.
My build:
Frame: Emax 280
ESC: Rotorgeeks 30A
Props: 6045
Oceans build:
Frame: ZMR 250
ESC: Rotorgeeks 30A
Props: 6045 Gemfan
Thanks guys.
Robbie
