HI, i built myselfe a tricopter that weigh's about 850g with everything installed. I'am running it with 1000kv motor's with 9x4.7 props.
the setup is rated to do 630g(x3=1890g) of trust with 3s battery.
I'am giving it full throttle and it is so close to lift but doesn't.
Motor's:
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=25082
Esc's:
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2164
using the KK2.0.
The motor don't sound like they are running on high rpm.
I calibrated the esc via the kk2.0 as it supposed.
the esc's are making biping sounds when iam in the KK2.0 menu
So should i change props? Or mabye the esc doesnt work well with the kk2.0? Any suggestion is appreciate!
Motor's:
Esc's:
using the KK2.0.
