I havn't been very clear on my goals:
-3-5 mile FPV would be preferable
-Can carry Gopro
-can be viewed through goggles and screen(start with just one)
-Has OSD with GPS and RTH functions
-Costs preferably under $1000
-Has LED lighting
Crazy goals:
-has IR camera for night flying
-can go 10 miles
I have been planning for a while. I have a plan, I just want to clarify stuff before I get in to deep. I am currently setting up a 501c non-profit so funds will come through events. Thanks for all the help. Here is my final plan, tell me if you see anything wrong with it.
I will use the Bixler. using a 30 amp ESC and a 6x4 prop. FPV will be recorded with a camera and sent back via a 500mw 5.8ghz TX. integrated into that will be a nova OSD. Separate will be a GoPro recording below at the ground at an angle. At the ground station will be a 9x with either a Frsky unit with 1 watt booster and patch antenna
or:http://fpvhobby.com/127-433-mhz-long-range-rc-system.html. a 433mhz system for long range. That would run with a 2.4ghz 500mhz tranmitter(I think this is the better option
The first one is proven, the next one I don't have much on. If anyone has any experience with 433mhz and this system exactly, is is worth the money?
Thank you guys for all your help, you are really helping.
Ben
