The FT Alpha was designed to be a quick and easy to fly build, an all-around best performer out of the Triad series. The FT Alpha is compatible with the FT Bravo and FT Charlie kits.
FT Alpha Airplane Specs:
[*=left]Weight Without Battery: 8.1 oz (230 g)
[*=left]Center Of Gravity: 14 inches (355 mm) from the nose
[*=left]Control Surface Throws: 16 degree deflection/ Expo 30% (increase based on skill)
[*=left]Wingspan: 24 inches (609 mm)
[*=left]Recommended Motor:2300 kv 2204 size motor
[*=left]Recommended Prop: 6.45 CW Reverse Prop
[*=left]Recommended ESC: 12 amp minimum
[*=left]Recommended Battery: 850 MAH 3S
[*=left]Recommended Servos: 2x 5 gram servos
The FT Bravo was designed to be a quick and challenging to fly build, this is the fastest and most agile plane of the Triad series. The FT Bravo is compatible with the FT Alpha and FT Charlie kits.
FT Bravo Airplane Specs:
- Weight Without Battery: 8.1 oz (230 g)
- Center Of Gravity: 14 inches (355 mm) from the nose
- Control Surface Throws: 16 degree deflection/ Expo 30% (increase based on skill)
- Wingspan: 24 inches (609 mm)
- Recommended Motor:2300 kv 2204 size motor
- Recommended Prop: 6.45 CW Reverse Prop
- Recommended ESC: 12 amp minimum
- Recommended Battery: 850 MAH 3S
- Recommended Servos: 2x 5 gram servos
The FT Charlie was designed to be a quick and easy to fly build, the slowest and least agile of the Triad series. The FT Charlie is compatible with the FT Alpha and FT Bravo kits.
FT Charlie Airplane Specs:
- Wingspan: 28 inches (711 mm)
Each airplanes’ wings are built to be removable from the fuselage, and can be swapped with any of the other Triad planes, giving the builder essentially 9 planes to choose from.
The Swapping Of Wings Takes Less Than A Minute And Is Supported By Rubber Bands!
There is no need to re-calibrate the center of gravity on the aircraft after swapping, the CG remains the same no matter what combination you configure. This is great for the flight line and swapping with others, making it an enjoyable experience for all.
We want you to have an amazing experience both in building and flying.
Release Date: 12/12/2016
Article:
Release Video:
Build Videos:
Plans:
Charlie: FT Charlie Plans
Speed Build Kits:
Alpha
Bravo
Charlie
Alpha Bravo Charlie - Combo Pack
This kit comes with everything you need to complete the FT Alpha Aircraft. Push-rods, control horns, firewalls and all other items needed to make this airframe electronics ready are included in the kit. If you choose to purchase our power pack F and battery, balance, flight performance and assembly will be quick and easy.
