Is is possible I got the wrong prop with the kit. The prop is spinning ccw as per the build video. The numbers on the prop are pointed toward the nose. But the plane wanted to go backward, holding it in my hand . Launching it went straight into the ground.
Perhaps I needed this one: https://store.flitetest.com/hq-6x4-5-standard-ccw-props/ rather than https://store.flitetest.com/hq-6x4-5-reverse-cw-props/
First plane. First build. I'm probably doing something stupid. Thanks all.
This is not my first plane, and I'm having the same problem with the Bravo I'm building.
The motor is spinning counter clockwise when viewed from the rear of the plane, just like in Josh's build video. The bag I was sent was labeled Emax 6.30 CCW Prop... but if I put these things on this plane it's going to try to fly backwards.
