I maidened mine this evening. I am very happy with this plane. I had a mini FT-22 and I hated it. It always felt like it was on the edge of a stall and though it looked cool I did not enjoy flying it. I like an airfoil. This plane is great.
Thoughts on the build.
1. The canopy and the nose are as hard as you want them to be. Perfection takes time but decent results are not too hard to achieve.
2. I changed the control horn location about 3/8" inboard and used linkage stoppers on the inside of the horn to reduce bending on the pushrods.
3. The hardest part of the build for me was the skewer for the backside of the wing mount. The holes on my SBK were off a bit and interfered with the servos. If I had to do it again I would run them through before the servos, top plate and power pod was installed. Instead I used a skewer for each side.
4. Power with a 2204 is adequate but I think a 2205 would be more fun. 4S could be a blast for a skilled pilot.
5. Get the SBK for your first one. The body has a ton of small cuts but all of the other pieces are standard. Get one and modify to your taste.
6. I want a swapable sized plane with ailerons. The roll rate is weak and a larger plane with ailerons would be a blast and look awesome in the air.
Good flying.
https://www.facebook.com/groups/FlitetestFans/permalink/1886285131590025/
