Timmy
Fine for the RH elevator but the LH one at the end of the cross link will be very 'flexible' by comparison.
Push rods only work well when the servo arm and horn are in a direct line.
In addition if you look at geometry the ends of the elevator horns will tend to be further apart with 'up' elevator and closer together with 'down'. Your cross link will not allow that so something will have to 'bend' a bit making the servo work harder just as it is having to overcome the increased aerodynamic load from elevator deflection.
'Angled' hinge lines do create some issues. By far the easiest solution is to use a dedicated servo for each surface.
