XF VIPER - Foamboard F-16 EDF
IcedStorm777
The helix will be your best choice.
Looks like it has a 24x18" working area (approximately 610x460mm) so, you are probably going to have to make your own cut files.
Your going to have to become comfortable with a CAD program of some sort to take the "pieces" and rearrange to fit the Helix's working area.
"Cutting" verses "Etching" on lasers is a function of power/speed. I cut my foam in two passes to help minimize the cut back because the heat of the laser will melt the foam a bit and it will form a cupped area at the cut line. You are just going to have to play with those numbers until you find ones that work (or maybe someone here has experience with Epilog equipment.)
There's at least one other thread talking about laser cutters, so I don't want to hijack this one any more. ;)
Ok thanks for your help i'll tell you how\if the build works!
Mid7night
Jetman
I really appreciate the support!
I echo Chuppster's sentiment; it's not an easy build, but it is SURPRISINGLY easy to fly - it even surprised me! You can go crazy with it, but you don't have to. Don't be shy with your questions (I don't think you have a problem there ;) ) and we'll help you along as best we can.
IcedStorm777
I really appreciate it!
Chuppster
Also, im putting a turnigy 2226-3000kv brushless outrunner into a 70mm 12 blade fan unit. do you think that will be enough power? I have a 3s 3200mah battery. do you think i would need a bigger battery and if so what would you reccommend?
The outrunner:
https://hobbyking.com/en_us/turnigy-2226-3000-70mm-edf-outrunner.html
The EDF unit:
https://hobbyking.com/en_us/blade-high-performance-70mm-edf-12-blades-ducted-fan-unit.html
The battery:
https://www.horizonhobby.com/3200mah-3s-111v-30c-lipo-battery--12awg--ec3-p-kxsb0017
Sorry, i'm a bit clueless about EDF's
I used that outrunner on that EDF and it draws too much current. I recommend a 6-blade EDF for that motor, I'm running it in my A-4.
Mid7night
Jetman
Yeah that could work. You just need to find the right motor.
It won't have the sound of the 12-blade, but the price is nice!
IcedStorm777
IcedStorm777
In the plans, what is the difference between the Blue lines, the red lines, and the black lines? I know it is the same as flitetest but as the only plane i have scratch built was off of RCgroups, I don't know what the markings mean...
Chuppster
Blue and red mean do a score cut. The difference is the red lines usually infer that you need to remove the foam while the blue lines usually indicate a crease. The black lines are cut clear through.
That fan from Aliexpress is considerably cheaper than the same ones from Banggood. Let us know how they work out please!
It works great! Goes like stink.
IcedStorm777
Oh ok thanks for clearing that up!
AkimboGlueGuns
Biplane Guy
A blue line does NOT mean cut through. The blue line on FT plans is a reference line and should be marked on the foam piece you are working with, but it should not be cut through.
Chuppster
Hmm. I scored (50%) all of the blue lines on this design and it worked well. I do sometimes just use my fingernail for blue lines, if they are for placement reference. But I thought that's what the green lines were for.
IcedStorm777
@Mid7night
I want to put retracts on the F-16. I want them to be kind of like the retracts that you put on the F-4 Phantom. How did you do those? can you put a link to the servoes you used?
Mid7night
Jetman
I try to keep my line colors in line with the FT plans, but Dan is much better at organizing that than me. For my plans, in general:
Black Lines: Cut 100% thru
Red Lines: Cut thru 1-layer of paper and most of the foam, NOT all the way thru. Usually a place where either a single or double-bevel will be cut, OR a foam-channel will be removed.
Blue Lines: Score cut thru paper, maybe 50% of the foam. Usually denotes where a crease-fold will be. Depending on the severity of the fold angle, you may need a deeper score to bend.
Green Lines: Reference alignment markings like centerlines, CG marks and layout guides.
Magenta Lines: Usually reference text to identify parts.
Mid7night
Jetman
@Mid7night
F-16 retracts are highly unique, they are not anything like what I used on the F-4. I would start by searching MotionRC or Hobbyking for retracts specifically labeled for F-16 use, as a start.
That said, you MIGHT be able to use more "standard" retract units, but you would have to modify the internal structure significantly to hold onto them.
IcedStorm777
Ok thanks. What are "standard retract units?"
