Wildthing
Looking good! How did you get all the tabs aligned perfectly without a jig?
I taped the ailerons inplace plus had masking tape on corresponding edges to mark center of each hinge. Then with my Dremel and it's tiny cutting wheel , used 1/64" plywood as a spacer for the Dremel and held it vertically a it got the cutting wheel to the mid point of the edges . The dremel itself I just held at 90 degrees or very close to it and then started cutting . Steady and smooth and they all lined up at first crack.
