JJBTEXAS
I was recently inspired by mpbiv's build and ImmersionRC's new Vortex and decided to design another quad.
As you can see, the design is heavily influenced by the ImmersionRC Vortex. You may also notice it's far from finished.
At this point in the project I would like to do something a little different and ask you all for advice. Is there anything you can see or think of that you would like to see in a quad of this design? Is there an aspect of the design that you believe could be improved upon? I'm trying my best this time around to design it perfectly once instead of printing so many prototypes.
The next step for me is to work on the FPV system which will most likely be mounted into the front of the chassis, as well as work out placement for the VTX, RX and battery.
Checklist:
Checklist:
- landing feet (probably use similar system to my Mighty Mini)
- more support structure (want least amount possible, probably just long sides of chassis)
- 3D printed parts using Ultimaker 2
-Red: eSun PETG
-Florescent Yellow - SainSmart
-Black: IC3D ABS - Carbon Rods: .65"x.55"x4" from Rock West Composites sku 45102
- Acro Naze 32
- EMax Mini Quad Combo from getFPV
- 1300-1500mAh 3s
- Turnigy Battery Strap
- 50g Dampening Balls
- plenty of countersunk and button head M3 screws of various length
