Niez13
The bottom is beautiful with all the intakes that are scale and functional! Even though you say it's not the final version, the seems are great!getting down to the nitty gritty here. push rod stirrers installed, servo tray in, plans updated. took a few notes of what's left. geeze I hope it flies well 😆🤣😂 View attachment 198304
left to do on the design and plans
-servo mount holes and control horns slots on plans
-canopy design...clear and foam board options 😆
-front cowl ring
-wing skirts
View attachment 198305 View attachment 198306 View attachment 198307
I'll probably get the electronics installed this weekend. Tons of room for whatever battery I want! I'm still not sure on cooling.... I the intake under the cowl makes it into the fuselage, but at this point there isn't any room between the battery tray and the top of the wing. I'll figure it out soon enough I guess!
getting close on the specs:
wing span 48"
length 38"
weight (no battery) 550g
power 2216 1120kv
5 channels (built with flaps)
One note on the tail is I would keep it how it is laid out now with the one piece from the back cockpit to the tail. That way its less pieces, and lighter because you don't need formers. If you were to add a piece to do it like my FW190 it would add weight, and by how tight the formers is the seems might not add up perfectly(sort of). Basically the thickness of the foam on the seem line would get smaller and possibly leave seems that aren't flat with each other. I hope that makes sense, don't know if I have a photo to show how. But it looks good now so don't worry!
