KKArioKA
Epoxi Flyer
The Main Reason i did this, its because i didnt wanted the motor to be GLUED INTO THE PLANE, this way i can remove it and replace when needed.
1 - Ill glue the 2 strips of white rubber (bottom of the pic) to those side channels on the motor mount.
2 - I measured the pvc tube to its lenght and Diameter and cut in the size of the nacelle. test the position of the motor mount and made 2 holes on each side.
3- Fix the Motor in the Wooden mount, use 2 drops of locktite on the tip of each screw.(ofc the part that goes IN the motor)
4- Shaved the excess of foam on the nacelle (Motor Mount Lodging), sanded and risked the pvc tube to adhere more to the epoxi.
5- Pierce THROUGH the FUSE with 4 screws holding the Motor in place and let the epoxi dry. (use a pin or needle from inside out to mark the place of the 4 holes - dont really need to do this with the motor attached)
MAKE SURE YOU TIGHT EACH SCREW little by little so you get a proper motor aligment.
6- not sure yet but i might do a protective cover where the 2 screws goes into the nacelle.
I know you like pictures
Enjoy !
You have my MSN, andre !!
Enjoy !
