Just received my Bixler and im having a little trouble mounting the Motor in place.
the motor mount seems small for the space, and looks like it sits off center.
im planning to do a motor mount adapter with 1/2" tube glued to the fuse; and fix the wood motor mount with 2 side screws .... any suggestions ??
Its safe to scrape the excess of foam that compress the motor mount ? or the mount need it to have a peg to glue into it ? the casing of the motor is stuck with that excess of foam and its not turning freely if i push the mount to the rear end ...
PLZ HELP I NEED A SOLUTION !!!
