jamiedco
Prop Killer
hello all
since going threw David's site (rcexplorer.se) i have been wanting a dlg .
but i am not that skilled with gliders so i don't want to spend a few hundred dollars on a dlg that i will probable kill .
so after some searching i found a foam board dlg so when i kill it it will be cheap to fix or replace .
first i built this thing but i killed it on the first launch as the wing and control surfaces were to small aswell as it was over weight .
so i moved on !
so after searching the interwebs i found Ghostlift's forum pages on rcg .
the plans are available there
http://www.rcgroups.com/forums/showthread.php?t=826408
so i pulled the plans and built this beauty
the auw is 262g which is 62g over design weight so im a little worried about the maiden this afternoon.
the setup is as follows
2 x hxt900 servos
1 x hk-gt2r reciver
1 x 350mah 4.8v nimh battery
i will post footage of the maiden if it goes well today
so now lets share this part of the hobby and get more people into glider flying by making them easer to build and cheaper .
feel free to post your builds and plans for foam board dlg and hlg planes . any input will be appreciated
so i moved on !
2 x hxt900 servos
1 x hk-gt2r reciver
