I converted a speed build kit FT Nutball , into a snowball with the conversion kit. I am using the B Power pack as recommended. The CG balanced, slightly nose heavy. On it's maiden, it scooted across the snow and took off only to roll hard right and dive into the ground several attempts. Can anybody tell me why and what I need to try in order to have it fly stable as possible? Or fly at all more than 5 secs.
The rudder and elevator are neutral upon powering up and throws are as recommended.
The ESC and battery are within the motor mount pilon area to get the CG. Receiver is directly behind the motor mount pilon.
Thank you
Thank you
