The big bang of Mustangs
Wildthing
Also, if I go down in propeller diameter, but increase pitch, would I get more speed, and would I pull the same amps?
You need to get yourself one of these, doesn't have to be this one but lots to choose from and they are relatively cheap that way you can test each motor with whatever prop and you can adjust from there
https://hobbyking.com/en_us/turnigy-180a-watt-meter-and-power-analyzer.html
Then one step farther is to also test the thrust with each combination so you can setup your power setup before it's even in the plane. :)
https://hobbyking.com/en_us/turnigy-thrust-stand-and-power-analyser-v3.html
K3V0
Kinda rushing this cause I want to go back to the DGA-6 build which will put all my other builds on hold for a while.
Ha, this is kinda how I feel! I’m in the middle of the bushwhacker build too! The mini mustang is pretty simple but it has taken some time. I got to work on the wing last night but I hadn’t prepped my servos so I shelved it at midnight.
buzzbomb
I know nothing!
Ok. It's taken some electronic surgery, but I've got a working 30 amp esc, 4 channel receiver and a 2836 1100kv motor. Full-sized Mustang it is! Whoots! Tonight I'm tracking down two twelve inch servo extensions, two six inch and four 9g servos. If I've got all that, then we are go for build! :D
The Hangar
Fly harder!
Sweet!
