Wildthing
You need to get yourself one of these, doesn't have to be this one but lots to choose from and they are relatively cheap that way you can test each motor with whatever prop and you can adjust from thereAlso, if I go down in propeller diameter, but increase pitch, would I get more speed, and would I pull the same amps?
https://hobbyking.com/en_us/turnigy-180a-watt-meter-and-power-analyzer.html
Then one step farther is to also test the thrust with each combination so you can setup your power setup before it's even in the plane.
https://hobbyking.com/en_us/turnigy-thrust-stand-and-power-analyser-v3.html
