Had some new foam board to try so did some plan mods and came up with this little beauty
New foam board has no paper backing so modified the plans to take this into account and used a few 3D printed parts for the undercarriage mount and motor mount. Rear wheel set up is just a 3D printed sleeve that goes over the bottom of the rudder and has the wheel and axle set into it and secured.
Opted for a single servo aileron on this wing as I raided the parts of a retired plane and it saved adding a new servo as the single set up works really well, especially as I decided not to add dihedral on the wing.
Motor for maiden was a DYS 2826 1000kv spinning a 9x6 APC style prop.
Managed a maiden last night and it's not bad at all! First flight was dialling in the trim and control throws, then second flight I decided to play a little more with it but nothing too crazy! Impressed with the feel in the air though definitely.
Just fluffed the landing on the second flight though - found it's tip stall point and managed to bend the motor shaft so it now has a 1400kv in it's place spinning the same 9x6 prop.
Looking forward to having some more stick time with this little thing - lovely relaxing flying.
Maiden flight video taken on hat cam...
Second flight taken by my other half - her first attempt at filming using a DSLR camera!
