More then likely it will, I won't be adding any thrust angle. It seems like 6 of one, half dozen of another. Down thrust may keep it from ballooning but pitch it down aggressively at slower speeds being the center of thrust is above the wing. Up thrust would solve the slow speed issue but you will be back to the same problems under acceleration.
Got some early morning work on the bench done:
Belly pan is on. Ironed the edges flat because of the angle of the sides made for an angled edge up top, helped seal off the exposed edges behind the pan. Gives it a stealthy look as well.
Which brings me to the nose. I cut a diamond pattern out of paper just to see how it would fit up to the wing body and just by looking at the shape of the original nose and motor cowl, it would be difficult to transition from a diamond shape to square for the motor mount and still keep the nose slimmed down enough to not take up a lot of space on the front of the plane as it sits. It also would take up a lot of inlet area as well. The nose was kind of a "see how it goes" thing as the build went on, if i planned it out better or had a CAD program I could draw it up better before hand instead of just trying to go by what the voices in my head are telling me lol.
In order to raise the wing up the fuse and get the center of thrust closer to the center of the wing I extended the sides down 3/4" down, this also helps to get the bottom of the cockpit flush with the belly pan, and not sagging down like a double chin. The cool thing that turned out of this is I was able to taper the back of the sides to the original height to help with a more realistic profile.
On the nose however I will be tapering the sides of the cone just like it is on top and bottom, so there will be some profile to that as well.
More to come.
