Over the last few days I have been working super hard to finish building V2, so I can maiden it today. So hard that last night I even stayed up till 4am to finish it, even though this morning I had to get up at 6:30am, so although I am exhausted and so not focused I am super happy. Why?! Because this morning I got to maiden V2 and it flew, it still has handling issues that I need to work out but I managed to fly a whole battery on it. Again I forgot to weigh it but this time it came home undamaged so I don't have to pick up and weigh pieces
. What I do know is that I will have a huge difference on the weight between the two wing sets that I have created, the Master Series type wing being heavier. I also seem to have issuing balancing the plane out this time and it's not balancing using a 1000mah 3S battery like it used to even though I mounted the servos in the fuselage this time instead of the tail boom; so need to check that out. I also still need to make a lot of cosmetic changes to the plane to get the covers and everything to line up nicely, but that's something that I am leaving to the end. I have done the tests that I wanted to last time and couldn't so a lot of things learned from that, for you to be able to give me your feedback it will all be in the video that I will edit over the next few days.
I have learned a few things from the test though. I found out that the glide slope of the plane is horrible so I am either too nose heavy or generally thats how this plane is. The elevator has great authority and effects the plane termendously with every change on its position. The rest of the control surfaces though (rudder and ailerons) didn't have much authority and their effect was minimal, something I need to think about. I know that enlarging the controll surfaces will increase their authority, but that will change the design so I am not sure what to do yet. This plane loves speed it needs speed to fly good, and the way it was designed allows you to up the power setup and get a wide flight envelope.
Here are a few pictures of the plane before it's maiden today with the new set of wings. This wing is built similar to the way the Spitfire wings are built, having an undercamber to help with wing stalls.
Here are pictures of the two different wings that I have built and wanted to test. I haven't tested out both wings though because once I got it to fly ok with the new set of wings that I have created I didn't want to risk the plane.
I also took a ton of pictures during the build process so probably tomorrow I'll sit down to write a post about the build process including and explaination of what I did, how and why followed by all the pictures that I took.
More tomorrow cause I am too exhausted to think straight at the moment :/.
