buzzbomb
I know nothing!
All caps and 3 and 4 had 0 chance of happening. Yep. I'm guessing it quickly turned into a bad night.1) DONE.
2) IN THE WORKS.
3) NOT HAPPENING TONIGHT.
4) NOT HAPPENING TONIGHT.
2) IN THE WORKS.
Actually was a quiet night but the build of the modified TT was something that I wanted to do carefully, so I took my time. Wrapped it up at around 4:30 when my shift is till 7 so prefered not to start something new and continue planning the modification of the TT while I document the build process to share with you all later on...All caps and 3 and 4 had 0 chance of happening. Yep. I'm guessing it quickly turned into a bad night.
Oooh!Actually was a quiet night but the build of the modified TT was something that I wanted to do carefully, so I took my time. Wrapped it up at around 4:30 when my shift is till 7 so prefered not to start something new and continue planning the modification of the TT while I document the build process to share with you all later on...
It is programmable and is set by default to 3.3v you still recommend changing it? How strong is the buzzer do you really hear it?Some of those battery buzzers are programmable. If yours is, set it to 3.5v per cell. The default is something like 3.0v, which is too low because the voltage falls off a cliff once it goes past 3.5v.
Yes, definitely 3.5v. even with that, you need to land very soon after you hear the beeping.It is programmable and is set by default to 3.3v you still recommend changing it? How strong is the buzzer do you really hear it?
I use them and have mine set to 3.4V. When the alarm sounds you have enough time to cut the throttle to minimum, and start landing. There is a small reserve at half throttle if you need to extend the approach and when you land the battery voltage should still be safely above the 3V damage point.It is programmable and is set by default to 3.3v you still recommend changing it? How strong is the buzzer do you really hear it?
That's at room temperature. I'll call it 70 degrees fahrenheit. What about when it's much hotter or colder than that?Here's a typical lipo discharge graph, so you can see why I recommend 3.5v. You will see that the voltage accelerates downwards after 3.5v. What you choose as your warning level is a matter of personal preference. I don't like to run mine down to anywhere near 3.0V.
The discharge curves are nice in detail and even look impressive but I run my batteries at around 20C or more in some cases. The voltage sag under load is far greater than the curved supplied indicate even for a new battery and older batteries sag even more. If anything they are misleading unless you examine the scales properly!That's at room temperature. I'll call it 70 degrees fahrenheit. What about when it's much hotter or colder than that?
You are not helping. Telling us noobs that we need experience to figure where to set the limit, doesn't help us noobs set a limit. We're just looking for a starting point, when it's not room temperature outside. We'll figure out the details with experience.The discharge curves are nice in detail and even look impressive but I run my batteries at around 20C or more in some cases. The voltage sag under load is far greater than the curved supplied indicate even for a new battery and older batteries sag even more. If anything they are misleading unless you examine the scales properly!
There is no set voltage alarm threshold and it is a matter of personal preference and experience.
Have fun!
If I'm understanding correctly everything drops off at 20% capacity at a given temperature. Mayan is trying to fly in Israel, myself South Carolina in the U.S. There will be no given temp. What I'd like to know is how do the curves change with temp? For myself I'm getting a programmable low battery alarm. From everything thing I've seen from you and d8veh, regardless of temp, 35% seems about right. All that's really going to change is when that 35% happens.Here is a link to a page with some LiPo characteristics for beginners; http://learningrc.com/lipo-battery/
As mentioned previously I run higher discharge currents normally between 20 and 30C so I copied out the discharge curve to illustrate the different curves under real conditions of discharge currents used in RC aircraft.
Learn and then make up your own mind!
Have fun!
That is good information, and I am going to bookmark it. You missed the point of my question, however. How does the voltage curve change with ambient temperature? At extremes. Temps where the glue melts or everything freezes. Perhaps more pertininant is do I even have to worry about it?Temperatures here in mid summer are not that different to Mayan's environment. I use a series of battery management techniques to prolong my battery life.
1. NEVER discharge beyond the battery's "C" rating
2. Never discharge a LiPo below 3Volts/cell
3. Never charge a battery that has an internal temperature above room temperature!
4. Never expose a battery to external heat sources, or direct sunlight for any length of time.
5. Never charge a LiPo battery pack at high current.
6. Never place discharged and warm batteries with fully charged batteries ready to be used.
7. Never fly to the limit of a batteries capacity on purpose. A flight timer is a good idea.
8. Try to keep batteries and ESCs apart, Both require cooling ideally.
9, If you need to add nose weight for balance better to fit a larger battery as the battery will last a much longer time, (Number and duration of flights).
How do I manage them! Firstly I cool my batteries in a refrigerator before i charge them and afterwards as storage.
If you need to charge a large number of batteries in a short time buy additional chargers. an extra charger cost about twice the price of a decent battery but doubling the charge current of all of your batteries can shorten their life significantly.
I charge my batteries at 1C or less!! NEVER more! NO FAST CHARGING EVER!!!
I fly until I start to get bored or I feel the time is right to land. The battery alarm is only a secondary level of protection. My batteries are COLD on arrival at the field and will remain below ambient for well over an hour kept out of the air and direct sunlight. I do not use a cooler or other insulated device.
So far I have attained battery life in excess of 18 months and in some cases safe storage of charged batteries of 12 months, (I broke the plane and it took a long time to repair). The batteries still do tend to self discharge but the loss is very slight.
Just what works for me! I recommend that each RC pilot develop his own battery management methodology!
Have fun!
