That would probably be workable for a straight wing where the wire is touching the same amount of foam all the time, but on a tapered or swept wing it would be changing constantly.
Hence the option to pre-compute : I supposed the amount of foam at the different points of the cut could be computed, and forwarded as an additional "parameter" in the gcode (like the laser power is piloted in "classic" laser cutters)That would probably be workable for a straight wing where the wire is touching the same amount of foam all the time, but on a tapered or swept wing it would be changing constantly.
Parts on order:
www.omc-stepperonline.com
x4 - Nema 23 Bipolar Motors 1.8deg 1.26Nm (178.4oz.in) 2.8A 2.5V 57x57x56mm 4 Wires
x4 - 6.35mm - 8mm Flexible Coupling 18x25mm CNC Stepper Motor Shaft Coupler
x4 - Nema 23 Bracket for Stepper Motor and Geared Stepper Motor Alloy Steel Bracket
Order total w/shipping to US: $115
Banggood.com
2x 8mm 500mm Lead 2mm Stainless Steel Lead Screw + T8 Nut For CNC 3D Printer Reprap
2x 8mm 400mm Lead 2mm Stainless Steel Lead Screw + T8 Nut For CNC 3D Printer Reprap
I cant remember if i updated the post or not but i ended up using 28 inch drawer slides in the horizontal axis so i ordered some longer screws and i ended up using the 500mm screws for the vertical axis.
"Enough" is an individualized problem. My current setup is a 700mmx1000mmx500mm cutting box. That's the area i can move the foam around. So right now its "enough" room to do the types of cuts i want. In the future im sure i will come up with something that wont fit in it and will have to figure that out.
Hey Nate, just saw this - Like Jon, I've had this on my list for a long time, probably 5 years but backed away because I'm not smart enough to figure out the software bits... on my own or so I thought. Thanks to you and everyone else for being a pioneer and blazing the way. I'm now reconsidering building one.
