bracesport
Hi Nate - so what is your recommendation for a CG point on this wing - I cut down a DTFB DLG wing to 1.0m (chord is 170mm, tip is about 110mm, and there is about 35mm offset to the tip) - Oh, it still has the DLG dihedral too - it is my first time with a wing and I have it balanced @25% and this required quite a lot of reflex to get it to launch?
any tips or insights welcomed!
Plank 2.0 is ready for maiden. Honestly the hardest part here at the end was trying to figure out how to program elevons in my x-lite as i hadn't used the version of opentx it has. Final weight and stats are in the second pic below. May be some time before i can get good wind and an opportunity to get maiden done.
