Pumpkin drop event
RCTimer KK board
Tritium
Amateur Extra Class K5TWM
#2
The KK 5.5 is a good board and I have one just like pictured. That is a good price delivered too. The only thing I like better about the hobby king board is the input pin spacing but that is not an issue since the board pictured comes with cables.
Thurmond
Tritium
#4
The pins for each plug (Ailerons, Elevator, Throttle, Rudder) fit a standard plug but on the particular board you show they are farther apart than .1" normal pin spacing. The HK board is .1" pin spacing in both directions. Like I said since the cables are included it is a non issue and if you use 4 input cables it is a non issue as well. It is only an issue if you wanted to use the 2 cable trick (First cable normally installed and next cable on signal pins only cross ways).
Thurmond
