Wasn't that right after you said "I'm going to medium rates"?...I put just a bit too much stress on it, apparently.
Lol.Wasn't that right after you said "I'm going to medium rates"?...
I feel ya, I needed a bit more elevator throw as well.
whats a spitfire ?
The motor was hot. I don't think it was TOO hot, though. Of course, I'm not sure when a motor is too hot. I've got some of them too hot to touch and had to let them cool down before the next flight.Nice man did the motor, ESC or battery over heat?
Ironically, yes it was! The nose was overweight by several grams and I had a hard time keeping altitude. The DR1 is not supposed to be a rocket, but was absolutely exhilarating to see a triplane shoot across the sky.Wasn't that right after you said "I'm going to medium rates"?...
I haven't flown it in a while. I bent the bottom wing at the root and the electronics went into my Mini Scout Biplane project. It's a handful in the air, but it's also really cool. Just watching a triplane cruise around the sky is worth the effort. Definitely worth the build time!I still have this kit sitting around and a 1300 mah battery to keep that weight up front...seeing how much fun you guys are having with it, I figure I'll try it out soon.
The speed kit will give me half a chance at a decent maiden and cut down my build time. Think I'll just paint the fuselage two tone, one color on the belly one for the rest, and leave the wings and tail brown will a few stripes or decals. Less work, no chance of warping the parts that need to stay straightest. I have no multiwing experience outside a sim though, and this is about as multi wing as it gets. Is the pitch very sensitive?
I found the plane very sensitive to throttle so I would say that yes.The speed kit will give me half a chance at a decent maiden and cut down my build time. Think I'll just paint the fuselage two tone, one color on the belly one for the rest, and leave the wings and tail brown will a few stripes or decals. Less work, no chance of warping the parts that need to stay straightest. I have no multiwing experience outside a sim though, and this is about as multi wing as it gets. Is the pitch very sensitive?
I found the whole flight experience to be sensitive. So much so that I named mine "Challenge." That's part of the fun of flying it though. This isn't a plane you can point in a direction and turn to talk to your buddy. You've really got to stay on top of it.Is the pitch very sensitive?
It's 3ch RET which is very familiar. It has a large rudder though and the description says capable of barrel rolls, so this is going to be touchier than any trainer or the V-Sliver by a lot.I found the whole flight experience to be sensitive. So much so that I named mine "Challenge." That's part of the fun of flying it though. This isn't a plane you can point in a direction and turn to talk to your buddy. You've really got to stay on top of it.
Sounds like a plan! If it doesn't fly on 6x3x2 I'm doing something wrong. Ill try that first and test others later.Sweet! Either battery will do ya'. I flew mine with a 3s 850, but I needed a bit of nose weight. Prop wise? I've never flown a three-blade prop. I'd say start with the 6x3. The DR1 is all lift, all the time. It really doesn't take much to keep it airborne and give it the capability of getting really stupidly fun.![]()
I agree with @buzzbomb either battery will work I used a 3S 1000mah and had about 15 mins of fly time with 50% throttle using a 6x4 2 blade prop. Waiting to see you finish bird and maiden videoI'll be ordering my Charlie kit here in the next couple days, but I've still got this DR1 laying around, and my skills are up to the point where I know I can handle it and I have an interest in having this in my fleet now. I'm starting my kit build tonight. I've got a lot of options. I could go with a 1300 battery or 850, thinking the heavier one. I've got a 2205 Radial and several varieties of props. Which one do you guys think would be best, 6x3x2, 6x4x3, or 5x5.5x3?
Only my 850s are slim enough to fit in the battery area so I'll try to get CG with those. I got some 3.7g servos that are a bit temperamental, but I'll see if I can get them working with this bird to keep down weight towards the rear and make CG easier without adding much dead weight. I'll post more pics later, but last night, I got more work done on the fuselage and motor mounted. I thought about painting this one, but don't want to deal with the warping and the time and the mess and whatnot this time around, I just want it to fly nice, so I decided to keep the FT brown as a base and add some flare with some vinyl sticker paper and an orange highlighter on its last legs, which I used to make the turtle deck and cowl a nice bright orange.I agree with @buzzbomb either battery will work I used a 3S 1000mah and had about 15 mins of fly time with 50% throttle using a 6x4 2 blade prop. Waiting to see you finish bird and maiden video.
