Yeah, it's a little crowded. Here's what it looks like to walk into my workshop on an average morning. In this case I've got all the airbrushing equipment / tubs pulled out and cluttering up stuff.
But after a couple minutes of putting all that away (the tub of airbrush equipment lives on top of the fridge behind the transmitter & field cases) it's ready for working again. There are actually 3 working surfaces hidden in here.
On the right is the table for my home built Lowrider CNC router & needle cutter. When I'm not using the CNC, the gantry pushes all the way to the left end of the table and the right side becomes my larger work space. I've got a sheet of glass I use for covering work pushed up on the foam spoil board for the needle cutter - usually the glass lives in a slot under the spoil board.
The white flat spot on the left of the screen is my magnetic building board covered in protective slick paper. Since the workbench underneath was covered in stuff when I first got that building board, I decided to "temporarily" raise it up on a support to make it a standing desk height. Five years later, I've decided I really like having it up high
Way in the back on the left side is the cutting mat
@TooJung2Die spotted - that's sitting on top of a movable stainless steel dentist office tool support tray. I usually use that as the holding place for the instructions & hardware for whatever kit I'm working on (hardware kept from rolling off in little trays). When I don't have those %@#@$ chairs in the way, it's easy to move the dental work stand around - but at the moment it's sort of stuck hovering over my main bench vice. The chairs are an almost year long recaning & repair project that's delayed again and again by my better half changing her mind again and again on how she wants them finished.
I'm happy to talk more about the workshop if anyone wants (two more pictures below that give a better view of each side) but let's get some airplane pictures in here too
So here's the Twin Falcon with the masking tape pulled off. I'm pretty happy with how she's turning out so far
One big mistake I made doing the paint was starting with the red side. I should have started with the lighter color - the yellow - and then added a couple drops of red instead of going the other way. Would have made it easier to get a more even gradient with the orange in the center instead of off to the side. But I'm just getting nit-picky I think - she looks pretty neat and unique this way. Just needs a couple RockyBoy penguins
