Servos in, bottom covered - ready to start the top.
First I grabbed the existing wing and traced over the pattern on some scrap paper - just doing one side at a time like the bottom.
Then cut out patterns from the paper and putting two layers of covering back to back, cut out matching pieces for each side.
I left a little extra around the sides so I can pull the covering as I'm putting it on the wing. Then I pulled the backing off the covering and laid the pieces out with a couple weights so they don't move around.
The next step was supposed to be "use the iron to seal the covering pieces together." But it didn't work. The adhesive is supposed to activate at 280-300F but as soon as I touched the iron to the covering on the glass, the heat dropped like a stone down to the 160 range, even when I started with 330F on the iron. Darn glass makes a great heat-sink.
If heat won't work, let's go to a chemical attack!
I had never used this Trim Solvent before, and wow. This stuff works - and stinks! With a little wetting on a paper towel I cleaned the top side of the white covering at the seam, and then did a quick wipe on the adhesive side of the gold and pressed the two pieces together. Instantly bonded! Repeat for the gold / red seam and wait a little while to make sure it's secure.
Look at that! One layer thick piece of covering with design ready to install!
Installation is quick and easy - just like normal. Tacked down the edge at the middle of the wing, pulled the wrinkles out and tacked the other edges, then did a solid job over the aileron.
After a quick trim around the edges I cut the aileron free and sealed the ends there too. Then I cut out my servo wire access hold and fished the wires up.
Overall, very happy with this process! I could have even better results paying more attention to the overlap amounts before using the trim solvent - I'm still very pleased with how this wing is proceeding and will just take that idea forward to the next project
