The AP Mini Mirage is easy to build. Two sheets of Foam Board are required. You can use your existing Mini Power Pod for pusher props with A or F-Pack electronics (with an ESC extension wire) and you'll have heaps of fun chasing this plane around the sky.
RELEASE DATE: November 12, 2017
VIDEOS:
BUILD PLAN:
DOWNLOAD FREE DIY PLAN
SPECS:
- WINGSPAN: 520 mm | 20.47 in
- CG: 125 mm | 4.88 in (from air intake)
- LENGTH: 700 mm | 27.56 in
- DRY WEIGHT: 205 g | 7.23 oz (without fuel tanks)
- ALL UP WEIGHT: 275 g | 9.7 oz (with 3S 850 mAh | without fuel tanks)
- EXPO: 30 %
- CHANNELS: 3 (THR | AIL | ELV)
ELECTRONICS:
- MOTOR: 2300 kv (1806 or 2204)
- PROPELLER: 5x5 or 6x4
- ESC: 12 A
- SERVOS: 2 x 5 g
- BATTERY: 850 mAh 3S
PICTURES:
And here with the optional fuel tanks:
