Oops! Have you set the zero position of the elevators with part G1 "ELEVON NEUTRAL GAUGE"?
What is the all up weight of your foamie?
Which electronic components and which battery did you use?
Here is a video of the hand launch:
Thanks for positing the hand launch video, I learned a lot from it!
To answer your questions I can confirm that the 4mm up neutral aileron position is correct.
The all up weight on the maiden flight was 498g
Battery 1300 mAh 3S
30 Amp BL Heli ESC
Racestar BR2205 2300kv motor
Dalprop 5.0x4.0 tri-blade prop.
For the remaiden I am going with the following set-up:
All up wieght reduced to 470g
Battery 1000 mAh 3S
30 Amp BL Heli ESC
Align 6.0x4.0 bi-blade prop.
What are your thoughts on this set-up?
I am unsure why the mass of my Mirage is 71% greater than yours? I have covered mine using sticky back vinyl which would add some weight but not that much. Possibly our foamboard is heavier than the Flite Test foamboard?
My 30 Amp ESC is 10g heavier than a 12 Amp ESC.
