Niez13
@foamboardflyer @Baron VonHelton Plans at 13thsqaudron.com. If you have any questions about the build let me know!wow, that’s a sweet looking plane. I need to build my own.
haha had a similar feeling when I met trent palmer and got his autographWow! Having Splinter189 answer your thread personally is like getting to meet your favorite rock star and getting their autograph. Thank you. No issues with the build so far; I'm going to take it slow and enjoy the process and keep sharing pictures as I go.
yep, definitely recommend 13th squadron for lots of nice master series style planes!13th Squadron has a nice big Stuka you can build once you're done with your Great War series of planes.
Snow on the ground and -11c so a good time to start mine. But I'm still going with 3 blade props and landing gear. Still going to follow you with intrest.
Question about " clear Gorilla glue " its says on box "for non-porous surfaces only" does that mean NOT to dampen the brown foam board?
Looking Good!BBQ skewer reinforcement for the vertical stabilizer and rudder pushrod location. I glued the skewer in first with some white gorilla glue, then measured the distance to know where to put the hole in the fuselage. I think it lodged in the spine, which should give the tall tail a little more support.
As for the rudder pushrod, its easiest to run before putting the spline in. I used some skinny gorilla tape to attach my coffee stirrer pushrod guides to the spline- that little hole in the F5 former comes in handy to feed a long piece of tape in. An extra pushrod is helpful to guide the tape as far back as possible before attaching. The paper hinge seems to work fine on the double thickness rudder. Overengineering? I'll smooth it out later with a hot metal ruler to melt the glue underneath.
If I remember right they said that it flies better as a tractor. The reason they did it as a pusher was because it looks better.Well hit my first big snag, must have looked at the picture on Flite Test page 100 times. Clearly shows plane flying with motors in pull configuration, but in the build it shows pusher prop configuration???????? I kept trail fitting the power boxes and just could not wrap my head around the pictures showing the motor mounting. LOL So motors in push or pull? Next question is to mount ESC inside wing and hope one never goes bad or mount behind the motor in side power box?
As a pusher you don’t have any air from the props flowing over the wing creating lift.Can some one explain " flys better as a tractor" better air for the motors? Not sure how to word my question. I guessing the pusher setup would have to fight the wing for air?
