All done with #3. Added a removable wing, rudder, plywood reinforced nacelles (for belly landings), and a BBQ skewer reinforced vertical stabilizer.
Dunno about painting it, as I'm really paranoid about weight. Folks that wanna build the EDF version may want to look at using a bigger 70mm motor running a 6S battery rather than the recommended 4S one I'm using. I have a buddy with a Flightline Me-262 that runs a 6S battery and may borrow it if the 4S seems underpowered. His plane is much heavier, but his scoots across the sky with a lot more vigor than mine. My ESCs are 80amp (and I don't know diddly about them), but I would assume
my current motor setup could handle a 6S. Both ESCs are buried in the wing, so if I smoke 'em they are going to be a pain to access.
I've also revamped the launch dolly (thanks again, Cappy) removing the foam pool noodles, adding a little more launch angle, and putting paint sticks in the front. Fingers crossed! The weather is supposed to be decent this weekend for a potential maiden.
