Joker53150 - My second batch of bargain airframes (two this time, for a total of five) showed up on the same day as yours (yesterday). Of my five (Wildcat, Skyraider, Grob, Spitfire, FW-190), only the Grob came with the control linkage hardware and prop/spinner (as well as two identical-twin pilot figures in the cockpit!). The other four had only the foam, canopy, and cowl. I've been putting together the Grob (that "strange-looking" plane
If your magnets don't seem to be catching, check them for reversal. On my Grob, one magnet was reversed...it was repelling the opposing magnet rather than attracting it! The hatch was more than just a tight fit -- it wouldn't go fully into the cowl at all. So I sanded down the top/front part of the hatch that slides under the cowl, being careful not to take away too much. I sure don't want it loose...because I don't trust those magnets to hold it in place. I had a problem with my second Corsair with the hatch sliding forward in flight enough for the catch at the back to come out.
Unfortunately, with the Skyangel planes, warped parts are more common than not. On my Sea Fury funfighter, the wings arrived severely upcurled literally to the extent of a Parkzone Radian! Fortunately, on small planes like these it's pretty easy to straighten out warped parts with a hairdryer on high heat and a little gentle/steady bending/pressure. Heat it up, then hold it in place till it cools. Don't use a heat gun -- that's too hot -- I tried that once and it caused instant "alligator skin" puffing.
The Grob is the only one of these funfighters I've seen that is designed with an optional 4th channel in mind. The rudder isn't hinged, but it has the cutout line well incised, and there are pushrod channels on both sides of the aft fuse (one for elevator, one for rudder), and the aft fuse servo pocket has room for two opposing servos. I'm definitely going to add/hinge the rudder. At the speed this thing will go, and the size of the rudder, I expect knife edges to be possible. I installed a Cobra motor in it that is almost exactly the same size and Kv as the funfighter motor, but much better quality (
link).
