Please excuse me in advance that this post is long. Over the last week or so I have been debating with myself if to continue posting things on this thread. Why? I’ll be honest and say, I don’t think the title fits the description anymore and so today I have finally decided that this will be my last post on this thread.
This thread has been a journey, my journey into this amazing hobby. One in which I went from knowing nothing about RC planes into actually being able to build, modify, create and fly them. I owe my success in the journey to many people out there. First to the FT team for the wonderful thing they have going; with free plans, excellent build videos and other inspiring content. To the forum and the many wonderful people that share their knowledge and support on it. To my wife for sticking up with my madness and children with whom out I wouldn’t have stumbled upon this hobby while looking for something that I can bond with them on.
During this journey I have learned a lot, and a lot of the information that I have learned from is actually in this thread. I’ve learned to fly different models starting with the best trainer out there the FT Mighty Mini Tiny Trainer all the way up to an FT Edge 540. I learned to experiment; resizing models that I have flown before to make things like the Mini Mighty Mini Tiny Trainer and the Mini Edge 540. I have learned to create; modifying models to give them different flying characteristics like the SpiTTT. So if you are completely new to the hobby, I recommend you read the entire thread; I know it’s long but it might help you with your learning curve and if it does, please just post about it I’d be very happy to know.
To conclude this post I’d like to share with you a few things that I have learned during this journey.
# When building any model there are many ways to transfer the plans to the foam board. I have two different methods that I use and pick which one to use depending on the model and on what stage it is, let me try to explain. When I have a model that has been flown before with a certain power system by me or someone else knowing it will fly well and I know that I want to have this model laying around the I’ll create long term plans for it. When creating long term plans I’ll print out the plans, connect the titled pages, then glue the full plans to poster paper (240g) using 3M Super 77, I will then cut out the plane parts, and score cut and mark the parts based on the plans. When I want to use the plans I place the parts on the foam board trace score and mark (a little difficult because sometimes the parts move), then cut out the foam board as you normally do to get all your puzzle pieces. Sometimes I’ll add another step into the making of the plans to stop them from moving when placed on the foam board to trace, score and mark. What I’ll do is using 3M Super 77 I’ll glue a plastic book wrapping on the back of the plane parts. When it’s dry I’ll cut off all the extra plastic book wrapping, now I’ll use 3M Super 77 just once more spraying the plastic booking wrapping on the back of the part and will let it dry for a good 30 mins. When 30 mins are over you will have a sticky layer that will stick well to the foam board and avoid the plan part from moving but won’t make a strong enough bond to stay glued and thus it can be removed after you’ve traced, scored and marked the parts. Then cut as you would normally do. When building a test model or one that I am not sure if I’d like to have laying around I use a fast build technique and stick the plans directly to the foam board using either thin masking tape if I don’t want the plans to remain stuck to the foam board or 3M Super 77 if I don’t care for the extra weight and then I’ll usually leave the plans attached to the foam board.
# On any build you do I recommend that you reinforce the holes where the BBQ skewers go through using an old credit card, gift cards, plywood, or poster board; reinforcing these holes will make things last longer. I personally use post board as it’s cheap and easy to find.
# Have spares! Spare power pods with firewalls and with or without a motor and ESC connected to them, servo arms, wing sets, basically anything that you can break and can easily be replaced at the field. Ain’t nothing more annoying than having charged batteries and nothing to fly while at the field.
# CRAP check before every single flight and after every single crash. If you don’t there will be consequences, you have been warned.
# Embrace your crashes. Understand that a crash is not a failure but a lesson to be learned and a way to improve and get better.
# Build, Fly, Crash, (Repair), Repeat! The more you do this the better you will get at everything; building, flying and not crashing
# ASK! Use the forum to ask questions, if something doesn’t work or you need advice post it on the forum. Everyone here will be happy to help with knowledge or even just motivation.
# A plane doesn’t have to look good to fly good, it hurts less when an ugly looking plane crashes.
# Share! We all love to see what you are up too and love giving a good word and advice too, so don’t be shy
! Plus it helps with one’s moral.
# Read the forum, you’ll always find something interesting to read and something new that you can learn.
# Experiment! Try things on your own the more you try the more you’ll learn, lessons learned alone are lessons learned for life.
# Have fun! After all that’s what it’s all about! If you are not having fun anymore something is wrong; stop think and rethink how to bring back the fun, come back when you’ve found it.
# Explore! Understand that every model you’ll fly will have a different flying experience, will handle different, and react different. After all the more models that you’ll fly the more experience you will get and understand what models you like more and which less.
# Learn to fly straight while staying leveled making shallow left and right turns , it seems easy but it’s not! Try it and you’ll find out.
# Learn to fly inverted if you’ve mastered this with a model you are in control of the model feel free to move on.
# When crashing take notice of a couple of fixed scenery in the field it will help you find your plane and / or use a lost plane buzzer.
# Don’t drain your battery voltage too low so you won’t ruin them. Draining a battery to low will make it not charge any more.
# Learn to fly in wind, you can’t keep waiting for the perfect sunny windless day, you might be waiting forever
I just reread the 45 pages of my journey and think that’s all tips I can think of. Any how this will be my last post on this thread. If you’ve liked my content so far and want to be part of the second part of my journey I invite you to check out this thread:
https://forum.flitetest.com/index.php?threads/the-second-part-of-my-journey.58013/. A thread that will be dedicated to the second part of my journey, which will be just as exciting as this one probably even more.
P.S. - Thank you all for your advice about choosing my next Tx, please don’t get insulted if I didn’t choose the one you recommended but after many checks that I have done I decided the the best one for me at the moment will be the FlySky i6x Tx with both iA6 and iA6b Rx.
