ligbaers FTFC22 builduary
Ligbaer
50 Percenter
Wings cut
wing half’s glued together
kf step glued
wing hole on fuse done (bear with me for how scuffed it is)
wing glued in plane
Ligbaer
50 Percenter
Things I will change for v2
1. wings a little higher up
2.improved tail mounting the current system is really annoying and came off several times during glide tests
3.(if needed) bigger elevator looks small rn, I’m not sure if it will work good
Ok I flew it, it was underproped so I will fix that, time to run to dollar tree for foam
FoamyDM
Building Fool-Flying Noob
Welcome to Build-ruary that mirage looks like a great first build-ruary build.
I HATE CUTTING PARTS out
Sharp blades helps along with metal rulers. (I prefer aluminum yard rulers). Amazon has a 100 pack of #11 blades for ~$18
As for weak wings, like they snap/open up in the middle, bottom or top? or are the tips... droopy?
I often will use stranded fiber packing tape tight across the bottom
I find cutting the parts out Soothing, like a meditation.
Ligbaer
50 Percenter
i am using sharp blades, and when i mean weak wings i mean they fold in flight.
(i will try the fiber tape tho)
FoamyDM
I found it to be more like 40-30-30 F-P-P but now I'm splitting hairs.
Tench745
Depends on the foam. I believe the Adams foam used to have lighter paper than it does now. Also interesting to note, the last time I checked, DTFB with paper removed from one side weighs the same as posterboard.
Ligbaer
50 Percenter
I started with nose cone (simple part as I haven’t built in a minute
unsanded
sanded (not perfect but will do)
fuse or smth (idk im just following build guide)
I glue doublers to belly pan
I put a side wall
then reciver shelf and other wall
canopy stuff
