ligbaers FTFC22 builduary
Ligbaer
50 Percenter
Next is wings And lower
fuse
Ok I have jigs and Sides in and is dry fit
I glued sides and put servos
(doing them some what correctly)
motor Mount!
esc motor wires
(I’m gonna print motor mount soon at libaray)
missing extension lead, gonna solder one tomorrow
glued fuse
its a mess but I’m gonna call it off for today.
Ligbaer
50 Percenter
Starting again today
(can’t make it to my lhs rn so I’m doing v stab)
so i want to put a rudder on this plane (I don’t know why)
and I didn’t want the servo sticking out so this is what i came up with
I put servo in
then i put styrofoam plates on it
then i sanded
Glued to top plate
I probably did this in wrong order but its fine
as the important parts are done
Ligbaer
50 Percenter
I put servo in
then i sanded
Glued to top plate
ok i im just about done but i need battery extensions and the lhs is closed (time is my worst enemy) so now its just canopy, turtle deck and linkages.
for clarification on the elevons i used normal 9g servos and for rudder i used a 17g because the plane is crazy nose heavy
Ligbaer
50 Percenter
I should of updated the last bits of building
But it’s all just sanding and linkages and I don’t feel like putting that here, I put a meh vinyl job and some acrilyc on the intake and canopy.
So after flying it the only thing that was damaged was the nose cone.
I LOVE THIS PLANE😃
Ligbaer
50 Percenter
Ok i started on the widgeon last night and got a good chunk of the fuse finished
(going off balsa plans)
v stab!
(was gonna make a really big rudder but decided not too cause differential thrust
Elevator stuff
as this isn’t a scale build as long as it looks kinda like a widgeion then I’m happy
(the tail assembly was kinda weak so i put strut)
Musdang
Not Quite Legendary
Ok i did wings and motor nacelles I copied what @Monte.C did for his nacelles but did them worse
and now its just final electronics and maiden!
! View attachment 218348
Woo hoo! Looking pretty good. Lets hope it holds together well. My friend you've got to take care with your cuts and precision. It'll come with more time in the boat. (y)
Where's the fuse? More pics. :)
EDIT: Oh there it is, further up. :rolleyes:
Ligbaer
50 Percenter
ok so here's my plan for the rest of builduary:
1.finish widgeon (electronics coming tomorrow) then either do the mustang or gamebird
2.then build a few other planes if i can fit them in schedule
those planes being
yak 130 prop jet: https://www.rcgroups.com/forums/showthread.php?2729215-Yak-130-MJ
and an f-16 i dont know whos f-16 yet.
the extra 300 stopped being fun to work on and I also don't have a monitor or a computer that wont sound like a xf-84 thunderscreech if i try to draw plans up so that project is on hold atm.
Musdang
Not Quite Legendary
those planes being
Dude, you can build so fast! We need to make your signature “A Plane a Day Keeps The Doctors Away”! Or something funnier. I’m too tired for anything funny rn.
Ligbaer
50 Percenter
well things aren't going to plan so i had to order some motors again
i'm starting on gamebird (hopefully tomorrow)
unfortunately i can find any 3 views or diagrams so its gonna be a a busy night
(If all hope is lost then i will build a sbach)
Ligbaer
50 Percenter
well i have thought about i will just build a sbach so i dont have a big headache.
inorder to take my head off of the issues i will go to a simpler build the yak 130
(why do business days exist i cant wait till wensday)
Ligbaer
50 Percenter
up date on the widgeon!
its done motors are in servos installed but im gonna hold off flying it because its been really windy.
im gonna start on my sbach soon
Ligbaer
50 Percenter
Started on the stx! My i was having trouble with making plans out of my fusion 360 model so i have parts cut now image.jpg
Spars were just scrap foam and rest is basic arm in wing
Wings!
(Ailerons will be cut later
Ligbaer
50 Percenter
I did the tail, instead of doing a conventional one i did a v-tail. Why? I felt like it
I also did fuse it was just a normal ft style box
(i need to come up with a name now cause its not really a timber x anymore
Now its servos, tail booms and what not
then o have to knockout the sBach
