Aero_Knight
There is a post for future FT Plan Ideas and there was some discussion on the P-38 and I decided to jump in and do a design from scratch and it ended up being a bit more than what the original goal was. Thoughts, opinions, ideas are welcome while I finalize the design.
Here is the result of a day of modeling:
Mini P-38/61 "Black Lightning"
Turns out the scaling I ended up with makes the design a mix of P-38 Lightning and P-61 Black Widow design characteristics. I will post patterns once I have time to make my software do them correctly.
Some key points:
-Twin Engine with up to 4" Props
-Swap-able Engine Pods (Mini Firewalls)
-Optional Rudder Surfaces
-Two spar wing attachment (Carbon or Wood)
-20" Wingspan
-Bomb Bay Battery Access
-Double Wall Foam Structure
-Prop Flow Surfaces
Variants:
Centerline Prop with 4" or 6" Prop
-Side Pod Inserts
-Swap-able Mini-Firewall
Push Prop with 4" Prop
-Fixed Standard Firewall on rear
Push Pull Prop
Tri Puller
Tri Pusher
Quad Prop (God-Mode)
If you are up to the challenge, here is a rough draft of the patterns with some corrections to the lengths that may work. I don't have time to indicate the bend types but I will get to them at some point this or next week.
NOTES:
-The PDF is ARCH D sized scales at 1:1 but I left dimensions to help manually scale it.
-The "bend" lines are the centers of the bend because the program does not model foam board style bends correctly so I have to manually add the cut locations and such so do not slice the dotted lines unless it is obvious you need to. Go with feel if anything.
-I forgot to make the cutouts to mount the pods to the wing underside. Not the worst since you can make appropriate adjustments to ensure the prop clears the center fuse.
-With the exception of the center fuse most of the pieces should be self-explanatory but feel free to ask for help.
GOOD LUCK!!
Some key points:
-20" Wingspan
-Prop Flow Surfaces
Variants:
-Side Pod Inserts
Push Pull Prop
Tri Puller
Tri Pusher
NOTES:
GOOD LUCK!!
