Ken-The-Woodman
This is my second build, the first was a 71" Telemaster. Bought the plans for a Telemaster and the GLT befor I ever touched a RC plane . Balsa was a natural choice since I've worked with wood most of my life. Started second week of Oct.and still have a few little details to finish up. That's about 5 times as long as it took to build the Telemaster. First thing I had to do was re-orient the motor mount by 90 degrees so the glow plug wasn"t covered and the exhaust would go down, not to the side. Added some extra weight by using bass wood instead of balsa for leading edge and other places I wanted more strength so I added 4" to each side of the wings, including the ailerons. I used 2 servos mounted in the wing with a Y harness for the ailerons. Plans called for a 4 oz. fuel tank in the cowl but I put a 12 oz. in the front of the fusal. Pans were revised in 1961 and didn't give any details for placement of servo,batt. etc. Finished up at 9.8 lbs. without fuel and 7.6 sq.ft. of wing. I'm using a 46 engine with a 12/5 prop. so I can get some air outside the slightly large cowl.
