Jackson T
Time to extend the tail servo wires! For the rudder servo I soldered on the lead from a broken ESC, and for the elevator servo I used a plug'n'play servo extension. I glued a piece of balsa to the connection between the servo extension and the servo lead to make sure it doesn't undo inside the fuselage.
This is the goofy wing mount. I know it doesn't look very professional, but I'm pretty sure it'll hold up to the loads. Next time I'll do more research and make the wing/fuselage joint much better.
