More covering!
I decided to frame around the servo arm at the tail, but I forgot to on the other side before covering
. I've cut away the covering over the area, and I'm most of the way through gluing the framework in.
I glued a piece of 1/8th square balsa with cross grain (super bendy) around the contour of the rear cockpit area, then sanded it using the TLAR method. This part helps to smoothly transition the lines from the rear turtledeck to the canopy.
The full scale PC 21 has a frame thing in the middle of the canopy. To make this, I laminated 3 strips of 1/16th balsa around a corroplast former. Then, I sanded it to shape.
I haven't glued it on yet, it's just taped there. I'll glue it in after I finish covering the fuselage.
