Done. I didn’t get pictures of it through the entire build process, but I did get a lot more than I usually do. It’s built pretty much like an FT Mini Scout, and there are some of the things that you would do with the Simple Cub build. You’ve got to put some braces in for the back of the power pod since the nose is tapered. I used a deck inside the nose to help to define the taper and to give the power pod 4° downward tilt.
Under camber wing like the Mini Scout.
(Foam board airplanes are so much easier to construct than RC truck kits.)
Here’s the motor deck. It also helps define the nose taper. I also hope that it adds strength to the nose as the last version was a little delicate and easily bent out of shape.
I cut the slot for the rudder pushrod on the wrong side, so I covered it up with hot glue and cut a new slot.
Tail skid. ‘Nough said.
Here you can see the back braces for the power pod and popsicle stick reinforcements for the landing gear. This is looking down from the top.
Finished product. 1806 2300kV motor, 6x4.5 bullnose prop. The wheels are oversized, but unless I change out for skis these wheels are better for flying off a snowy field (Fresh snow tonight.). It balances with a 2S 900 maH battery. Depending on the weather, and other things that I might have to do, I hope to maiden this plane tomorrow.
The original would sometimes drop a nose down and to the left in slow flight when turning to the right. I think this is because the rudder would lose airflow with the nose pitched so far up, but there might be another reason for that. Otherwise, it took off quickly, was easy to fly, and didn’t take a lot to land.
Version 1
I’m using my new go to TX, the Jumper T Lite for the Cubbish, seen here. (Okay, so it’s the Makerfire version.) I have a lot of FlySky receivers, and this transmitter can handle 50 or so different receiver protocols, and it uses OpenTX. $80 well spent. Still not sure I like the silicone cover. It feels kind of slippery in the hand.
I’m not sure I can get my camera girl to video me flying the Cubbish in the cold weather (It’s supposed to be 8° tomorrow.). It’s hard to talk her into videoing in the summertime, let alone winter (Still, 30 years and she’s still my girl!). I’ll get some sort of video of it flying. Should Version 2 fly well I will paint it.
