Your 1000 would work, if you can get the CG. The 2200 is better, you can mount the battery on the bottom under the wing and the pod. More then double the flight time. I went a different route and went with the 2200 battery in the pod and the ESC underneath, but it took some strategic mods here and there to make it work.
Here is a Scout that i built, moved the firewall forward by an inch or so. Brought the motor out for balance plus made more room for the battery, had to cut a notch in the wing as well. Had a removable turtle deck for battery changes too. In the pic it is on a balance stand so you can see how well it works, I have a thread on it
here
