Justanotherengineer
What should the motor ratio for this plane be? I was thinking 2:1 but is that too small? Too big?
I’ve been looking at wing load and wing cubic loading.
Here is was I think I can achieve:
AUW of 800g:
Leopard Hobby 3536(~100g)
40amp esc(50g)
servos (50g)
RX(20g)
battery (100g)
prop (30g)
Airframe(450g).
Thrust to weight ratio: motor can put out 1800g. So with a AUW of less then 900g will give me a 2:1 Thrust to weight ratio which is what most people recommend for 3D planes.
Wing loading and Wing Cubic Loading:
The original FT-3d has about 250sq in. of wing area and has a recommended AUW of 550g.
Wingloading=12.1 oz/sq.ft.
WingCubicLoading= 9.2
If I make a larger to 350 sq in. of wing area and have a AUW of 800g.
Wing loading=11.5 oz/sqft
WingCubicLoading=7.4
Scale of 1.2 from original FT-3D plans
Thrust to weight: 2.25:1
If I make and even large plane with 450sqin of wing area and a AUW of 1000g
WingLoading=11.2oz.sqft
WingCubicLoading=6.3
Scale of 1.35 from original FT-3D plans
Thrust to weight: 1.8:1
Thoughts??
Your way over weight for good 3d flight on the stock airframe. I would definitely recommend you bump up the plans to 125% giving you a 40in WS. Youll get Much better flight with your setup. What size battery are you using?
I'm looking scale up the FT-3D appropriately for my larger motor.
Here is was I think I can achieve with a larger version of FT-3d for weight:
AUW of 800g:
40amp esc(50g)
servos (50g)
RX(20g)
battery (100g) (~1500mah)
prop (30g)
Airframe(450g).
The original:
120% of Original
135% of Original
Thoughts??
Please re-read the post. I think there was a misunderstanding. That's exactly what I am trying to do and want to make sure that I scale it appropriately for my power set up. The two theoretical options that I have in the post are for a 120% and 135%. Do the Wing Loading and Wing Cubic Loading values look correct for 3D flight capabilities?
Any flight video?Well I finally flew it today! Man was is windy! Also my throws were way too much for a first flight. All and all it flew well, just need to wait for less wind and it all should be good!
I was able to get out this weekend to maiden my 130% FT-3D with an AUW of 920grams. It flew great and was super stable even in the 10mph wind gusts. I used 3/32" Music wire for the landing gear and large foam wheels. I can't wait to get some calmer weather and actually try out some 3d flying.
