Learn how to scratch build your very own foam board 3D FT RC Airplane. This is an advanced swappable plane, featuring full airfoil tapered wings.
FT 3D Build Plans Available Here::
FT 3D - Swappable [ FULL SIZE ]
FT 3D - Swappable [ TILED ]
TIP for printing the plans "TILED":
To print "tiled" use Adobe Reader X and in the print dialog select "POSTER", select "Cut Marks" and make sure "Tile Scale" is 100%. Then overlap and tape as required (after trimming the top overlapping edge).
(Thanks youtuber larrybarrick for this suggestion!)
Click HERE to see the POWER POD BUILD VIDEO
Equipment used in this build:NTM Prop Drive Series 28-26A 1200kv / 250w
Hextronic 9 Gram Servo
TURNIGY Plush 25amp Speed ControllerFT Firewall
FT Control horns
1 mm piano wire (push rods)
Additional/Alternate components:
Suppo 2208/14 1450kv Brushless Motor (Park 370 equiv.)
APC-style Electric Propeller - 8x4E
Suppo 18A Brushless ESC
Suppo SP-90 9g Micro Servo
FT 3D Swappable Plans 1-of-3 FUSELAGE
FT 3D Swappable Plans 2-of-3 TAIL
FT-3D-Swappable-PLANS-3-of-3 WINGS
FT Control horns
