narcolepticltd
I unbuild stuff regularly
It's not dirty, it's a fine patina that C0d3M0nk3y has been working on for quite some time.
so whats the skinny on ESC catching on fire?
Sorry guys... about the 'patina put-down'. I'm sure many have taken liking to textured build up ... but, my real concern is extra weight.
Just keeding... but, in a bit more seriousness, I think being able to easily clean while it is still damp is key, compared to trying once it has dried completely. If things are put together with something like that in mind, it might work pretty well, if that is what you find on your quad after every flight and would prefer it to be clean.
Another thing that could be done in combination is a light spritz of something like silicon spray-before, then use, and steam off after use - as a release agent, similar to car wax with bugs etc. from driving and that type of thing. This might also work to help repel water and so on, as it should be non-conductive.
I've also thought of using velcro - based covers for esc's and that sort of thing, where they can be removed, 'breathe' and cool better, etc.
I didn't see any kind of put-down so stop worrying
I've got a nice silicone conformal I'm going to be using on my escs once I finally can sit down to build again...
http://www.amazon.com/MG-Chemicals-Silicone-Conformal-Coating/dp/B004SPJOKK
tested it out just to see how it coats, and I dig it. it has a very low surface tension so it wicks into cracks and crevices more like an oil based paint would, and you can either leave it super thin or build it up in multiple coats (does take a while to dry).
because of the surface tension, all you have to do is get a bit on a small brush and run it across the component... doesn't blob up like liquid tape.
I couldn't get zip ties to fit through the holes on my board cam. Did you ream the holes out a bit?
You're getting your money's worth out of that puppy.![]()
Your copter reminds me of my motorcycle (and me) after 800 miles on the highway going to AZ.
It's me right down to the one clean spot.
How'd you build go? i got a gallery for Blackouts, Let me know if u want me to feature some content
http://www.icktrading.com/blogs/team-blackout
