Your hex looks great Invid, especially with the anodized purple hardware. That GoPro looks gigantic on the hex, or the frame is just really that small (I can't tell yet). I noticed you have a second antenna coming out, is that one for your receiver? Would love to see some more closeup shots once you get the time.
If you don't mind saying, where did you purchase your aluminum hardware from? I was looking into Fastener Express, but I'm open to other suggestions.
Can't wait to hear how it performs and your opinion on the hex once you get some flight time in. I'm assuming you're flying it FPV since I can see the vtx antenna, how was the mounting of the FPV cam? Did you run into any issues with it?
Thanks Twitchity. The GoPro does look huge on there doesn't it? It's not really that bad in person, but the frame is quite small...it was a bit of work trying to find a good mounting space for the minimOSD. It's a bit of a tight fit.
I got my screws from Fastener Express also. I'd have preferred red anodized but my Blackout quad uses the purple and it seemed like a good idea to keep that hardware common to minimize the expense.
The second antenna is for my EZUHF receiver...time will tell whether or not being that close to the 5.8Ghz video transmitter will have too much of an effect on the reception of my 433 Mhz control. Even if it does compromise my range a little, I expect that I should still be able to easily outfly my video which is what I want.
I will be flying it FPV almost exclusively. I rarely find myself flying LOS these days, usually just for a one or two battery break and to keep the LOS skills up. I much prefer FPV.
I'll let you know about the flight cam when my replacement comes in. I thought I had one but it appears that it died in a crash some time ago. I'm currently using a Fatshark CMOS camera which is a lot smaller and is just double sided taped to the upper plate.
I've been thinking about it, and I think a 2200 will probably be too small for this frame...the throttle is very touchy and I'm hovering at around 20% throttle! I'll probably reserve my 2200s for when I want to fly like a maniac for a short time.
