After building the wing and attaching to the fuselage, I realized that landing gear had not been considered. Figured that a wood reinforcement on the inside of the wing was a good idea, so drew up a plan right on the bottom of the wing and grabbed a knife. Beveled cuts were used to add strength to the cut out pieces. 13/32” birch plywood was hot glued to the inside of the cut outs, then reinstalled into the wings. The landing gear was bent out of 0.105” spring temper stainless steel wire and glued in per standard FT practice.
